Copper vs Platinum
Copper or Platinum plugs?
  • Total voters
    34
Iridium's are a great choice due to their physical construction (Fine Wire) and the properties that the electrodes are made from.
"Iridium is a precious metal that is 6 times harder and 8 times stronger than platinum, it has a 1,200°(F) higher melting point than platinum and conducts electricity better. This makes it possible to create the finest wire center electrode ever. The strength, hardness and high melting point of iridium makes it very well suited for a fine wire plug and for ultra long life spark plugs. Though better, it’s not perfect, it is very expensive, and at higher temperatures it oxides, thus rendering pure iridium as an expensively poor choice for spark plug construction. However when blended with other precious metals such as Yttria, Rhodium or Platinum, you can enhance those metals advantages with the superior strength and hardness of Iridium. Champion Spark Plugs have nearly half a century of experience with iridium blends in their industrial and aviation plugs, but advances in late model engine design have necessitated the need for iridium in automotive applications. The strength, hardness and high melting point of iridium allow Champion to manufacture their iridium ultra-fine wire center electrode to 0.7mm. One of the finest firing points in the industry! "
Champion is the worst company for spark plugs. You could not pay me to use their crap.
No one was advocating a brand. Just getting some of the technicals out there. I also used to call on the company as well so I have some familiarity with the manufacturing process.
"Spark plugs with fine wire center and/or ground electrodes operate better for two reasons. First, a smaller center electrode requires less voltage to jump the gap. This means fewer misfires, which will be seen in higher mileage and more horsepower. The second reason is smaller center and ground electrodes reduce quenching. Champion manufactures a variety of fine wire plugs for racing, powersport, small engine and automotive applications."
not one word on proper gap in a plug thread?:shifty:
ive gone through 2 motors faster than most people change their socks, let alone plugs! had platinum +4 in, still look good, but may go 764 now don't know
Trade secret
I iwill add the Nitrous plug rule of thumb is use copper only. You don't want stuff that can get knocked off the plug(platinum parts) you also don't want fine wires that can melt easy. Case in point put large log in fire takes forever to burn put thin stick in there and it burst into flame.
Gaps should be .054 right? N/A
also my +4 didnt have to do gap, came 14mm thread, .708 reach like all the rest BUT the 764 has a .807 reach is that the advantage?.090 closer?
Dont buy Accel coils.
+1. I know stock packs are about the best for almost any mods, but I don't know much about COPs; Accel Coil Packs are worse than stock (I'll have to find the link to the testing).
I junk next im gonna pick up some motor craft coils. Oriellys has them for 100 a piece but I'll search around till I get paid again.
What about the coils labeled under the performance coils. Msd? I'm sure it's only half true because there cheaper than mc
The non COP MSD coils kick ass. Even the COP ones do but they dont last long. Never heard anyone complain about the coil pack MSD though.
either way will they fit under the cover? msd cop's are the same $ anyways. ive used their control boxes 6al and coils and wires before in other cars
Will they fit? Uh, they were designed SPECIFICALLY for the Ford DOHC Modular cam cover.
well i was gonna replace mine today, the car has 80k and i dont know the last time the plugs were changed because i bought the car in september. what plugs came from the factory? anyway i pulled the plugs and had planned on using some 764's but they didnt look right, had the wrong gap (.035ish) and the ones in it looked good still. heres some pitchurs for those of you who dont know what these look like lol
Those Autolites don't look bad, but they did not come in it from the factory. If I was to guess, they probably have about 20-25k on them - they look pretty good. You're right, those gaps on the 764's are too small and plugs should always be gapped b4 being installed anyways.
They were not designed for an LS.
So to make this easy, yes they fit. Ive had them in a Cobra and its the same VC.
