UltimateSVT
- Joined
- Jun 21, 2009
- Messages
- 4,602
- Reaction score
- 166
Last night when I'm about to leave a local restaurant I start the car & hear a hissing. I walk back outside & the front is on the ground. The hissing is LOUD! Coming from the general compressor area. I turn the switch off & drove home. Early this afternoon I started working on the issue. I run the compressor with the fender cover off & notice the air hissing is coming from where all 4 lines meet at the drier. I move the hoses around & hear the hissing change while I play with the lines. I decide to replace the whole thing with a spare "NEW" Arnott compressor/drier that I had in my shed as shown below. I cut the lines to get a clean tip & install all the lines on the new compressor! NOTHING! The bastard is still on the ground! Also, both passenger wheels stayed stuck inside the fenders when I lifted the car. First time this has happened to the suspension! Usually as I jack up the car the wheels hang there but not this time!
What on earth could be causing the hissing(constant loss of air), I cut about an inch from each line so that if there were any leaks on the tips I would get rid of them but it's the same!
Old compressor
New Compressor
Sitting slammed! Jack stuck under the car
Old compressor
New Compressor
