JC1994
Dude, I am soooo jealous!!!
NICE stuff G-man.
I'm going to guess you already did this but I wanted to mention it any how as this is a major build that must go right. I have assembled many engines over the years, and I always checked the clearances on all my bearing surfaces (with Plasti Gage) as a final check as it doesn't take much time to do and is cheap. One tight bearing shell or other blip could ruin an otherwise great machining and assembly job. I trusted my machinist (I also having been one), but always double checked as it is cheap to fix at this point. Just sharing, keep up the nice work, "Cleanliness is Godly".
That wasn't put together dry, was it?
used mololy on the turkey feathers on the j-79 in the f4s have you checked your torque on the crankshaft rotation Greg i don't have the specs but just wondering. stay cool guy jd
Before I button up the bottom, I am wondering if I should put on a windage tray. Do these help out? Should I get one?
