Hankyman240
Thread title pretty much sums it up. My new 98 base is slammed after making an 1800 mile adventure, and as awesome as it looks, it really isn't that much fun to drive when it's sitting on empty airbags.
Tonight we tried swapping in a new air ride module that did not give a warning when it was installed in another car, no change. Tried swapping the front sensors out... no change. Didn't quite have the daylight to swap the rear out... but I can probably test that with a meter later on.
I have a Ford FSM, but unfortunately their diagnosis process involves a lot of code checking with a special code checking device I do not have access to, so it has only been of marginal help. There are some specs listed for stuff though, so my next strategy is to attack it with a multimeter and make sure everything is as it should be. Everything was supposedly working fine until a couple weeks ago.
Any advice would be phenomenal. I mentioned this in the "coming home" thread but since it's proven itself to be a little more than a quick fix, I figured it deserves it's own thread. Thanks in advance.
-Darren
-Darren
