jolinc01
thanks, what about the trim on the sides of the steering wheel and above the glove box? same thing basically?
The trim above the glovebox is easy. Open the glovebox and pull the trim out from one of the corners. The trim by the steering wheel is almost as easy. You will have to pop off the piece below the trim, since the trim has a small lip on it. After that pull the trim from a corner and disconnect the wires for the headlight, dimmer, and mirror switch. You will have to pop out the black ring on the ignition trim piece from the back.
