The tires on my 1997 Lincoln are too wide and have too much rolling resistance for good fuel economy. Has anyone tried using 15 inch wheels and tires from a Thunderbird and what were the results? I would imagine I could pick up a few mpg's.
A man that calls himself "Chicken" on this board put T-bird wheels on his Mark VIII. It works well.
And I would imagine that you are a total idiot fock tard. Oh wait! I dont have to imagine it. Its a reality.
Pull the 125 pound tow hitch off it and save some fuel.
Better yet, die in a fire. That will save you some fuel.
Yeah, but if I recall correctly, they were 16" SuperCoupe sawblades. And they looked surprisingly good on a Mark.
15 inch rims are too short to fit over the front brakes.
No, he does not do that. He just tows 4000+ pounds with the car and fills the bags with slime. Damn waste of a pristine super low mile Mark.just how bad is your fuel economy?
its a 4000 pound v8 powered full size car for pete's sake.
try a 60 k tune up first.
plugs, plug wires, o2s, etc.
Guy is a POS.
Going to a 15 inch rim is only increasing your sidewall ht, as the rim is smaller in diameter and the tire will need to compensate the ht by being a taller tire. And therefore causing unstability while driving, and the width only comes into factor for fuel economy when you increase the width of the tread which increases tire contact to road, which increases rolling resistance, which can cause lower fuel economy. Going to a lower ht tire over stock ht will increase the total rotation count per mile, and cost you fuel economy.
Using a 15 inch and going with a 225/60 15 will be smaller in total diameter than that of a 225/60 16, that being said, you would have to go to a 225/65 15 to compensate, which increases sidewall ht.
I'm getting about 24 mpg on the freeway solo driving which is typical for this car. If I could put on a pair of 15" Thunderbird wheels and tires and gain several mpg's, I would do it. If not, I'll stay with the stock size tires.
My Dodge Cummins diesel had wide tires on it when I bought it and when I went to narrow 215/80/16 tires, I gained 4 mpg's instantly. This is what got me to thinking about narrower tires on my Mark.
