Raped Ape
I was discussing with a few others in my coil conversion thread about pinstripe removal. In the past I have experimented with all different techniques on taking pinstripes off of cars without damaging the paint while doing it. I have done such jobs and been a total failure and some have been quite easy.
But there is one technique that I have found to be the best of all others. It involves no sweat, work out with a buffer, erase wheel or anything electronic. A while back ago while in the military I tried using different chemicals to removes pinstripes and I saw a bottle of Expo Dry Erase board spray that can be picked up virtually any where for cheap.
What I found is if you just peel up one end to be able to grab with one hand, and with the other start to spray the Expo Dry Erase fluid bottle in behind the stripe and pull gently at the same time and continue till it comes off in one stripe. It does not damage paint and I have never had to go behind and buff or was other than taking a wet hand buff pad and wipe off the dirt that was edged or behind the stripe.
It is the easiest and less energy producing method to date that I have found. Here is a couple of pics to show you what I am talking about and you can see that it comes off in one stripe without tearing if you are gentle. As you can see this is a 14 yr old vehicle with stock stripes coming off with ease and no mess or buffing required. But do not do this in the direct sun light, do it in the garage at normal temp.
As you can see the only thing left is the dirt from behind or edged from the pinstripe. One wipe and it is gone.
