GMAN
I'm changing my transmission fluid. It's a PITA putting the pan back on. Is black RTV ok to use to hold the gasket to the pan? What's the best way?
I had the reusabale gasket, but I am not going to use it, because the pan leaked. I am going to use this felpro gasket. I just need to make jure the 273 RTV is ok to hold the gasket to the pan.
I just got a normal paper gasket, then put the 4 corner bolts in proped up the pan.
i wouldnt put anything on the pan other than the factory style gasket or you'll be pulling the pan back off in less than a month.
