That is not a cat.next restriction is the weird lookin halfass cat that comes before the resonators the H-pipe and then finally the mufflers.
What experience is that? Do you have a dyno from known-good stock cats to "high flow" aftermarket ones that shows gains? One of the major issues with aftermarket cats, especially the cheap ones, is longevity. They are cheap for a reason; there are precious metals that are used in the converters that are very valuable, and there is nothing a manufacturer can do to avoid the added cost other than skimp on them.Past experiance... The Hi-Flow cats WILL be worth it!
Just my 2 cents
You are right, horsepower is just a number that is derived from the torque. However, backpressure does impact the torque curve. Dyno with stock exhaust, then dyno with open headers...you will see a gain at peak, but the area under the curve will be less.BS backpressure does not affect torque, torque is a function of HP. Less backpressure the better. Hell run it right off the heads you will have lots of power. I havent seen any top fuel dragsters lately with necked down headers for more low end power lol.
That is not a cat.
I know its not.
I dont know what the hell it is so i gave it my own name. I dont try to be serious all the time. people are too uptight on here.
i thought back pressure helped with torque maybe i am wrong?
You ARE wrong. Back pressure does NOTHING good. BP is created by a restriction. NO restriction in the exhaust does anything remotely good!
KS
thank you for your input, and its always great to hear what other people know.
so i will go 2.5"
does anyone know of any tips that will fit this set up and look nice at the same time?
KS
