FTINMARKVIII
wicked your the first to suggest aic ? could it cause the pressure drop
Jebus farging chris! Are you related to lincolnboy? Thats the biggest pile of mish mashed crap I ever saw on here. Did you even try to make that legible?mine has been dieing same conditions priced a pump at 260 + tax bosc fuel preasure at 10 when it has trbl starting and shld be 60 i'm told and it will sit and build up again this all found when being smoked for evap leak p171 p174 i believe were the codes the kept telling me the o2 sensors are gone everywhere i brought it but still going with jamies advice and most others that it is a evap leak just having a hard time finding it the old fashion way with starter fluid will pay 45 for smoke waiting on connection problem no garage up north here but sounds like i could give a shot on rust or ground since every other time ithas been ground issue or rust coausing me trbl please advise anyone do appreciated help thanks all 1998 MKVIII LSC
i would check AIC it might be as simple as that my .02
MOTORCRAFT IDLE AIR CONTROL MOTOR is the answer then
I think this is what they call HIJACK:gr_devil:
thanks MOTORCRAFT IDLE AIR CONTROL MOTOR is the answer
fuel pump ?
fuel pump ?
Or you can buy one from Sears for about 50, and don't you have the factory jack with the spare?
with her being pregnant and due any day its smarter to leave her truck in the garage where it is warm and clear from snow and ice just in case we need to go to the hospital.![]()
