LincolnRedDevil
Will the exterior light warning come on if I put in Aftermarket H.I.Ds in the Mark???
i have after market in my 97 and i have never once gotten a message even with auto lamp on.
Yes. No. Maybe. Sometimes.
Those are the answers you will get. I just searched to be sure and thats what comes up under the search when you use the search function.
There is your "sometimes"When I put the HIDs in my brothers car the message only came on when the autolamp feature was on. If you operate the lights manually (by physically moving the switch) then you shouldn't get a message.
There is your "no"I don't get a message, I use the auto feature, mine are plug-n-play
There is your "yes"I get it on Jamie's former '93 whether you use the auto lamp feature or not.
if it does come on, its not like its hard to shut off. one wire up under the dash somewhere, i don't remember where though.
first gens are gay
you should trade me then
We'll just see what happens. Gen 1 and I believe it's the brown wire under the dash on the passenger side somewhere. I'll find it.
There's no reason to use relay(s) on a Gen 2, just wire the new ballasts into the feeds for the stock ballasts at the bottom of the radiator support.
^with my gen 2, there was a few times in the past the lights would flicker when my air compressor came on. since then i have replaced the compressor so i think it was just getting ready to die and was pulling a ton of voltage
i have to wait till the compressors shut off, the twins pull alot (over 70 amps) but i havent had any problems with then flickering but they will dim with the stereo up and the car at idle![]()
