Same here but fortunately mine is in my brothers garage getting upgrades. Were are you located in North Carolina. I'm in Fayetteville.
My friend Eds house. First pic, there is a Fox Mustang by the fence under the snow.
wow. that is something...
but today, new p/s rack. bushings in the old one were shot.
tomorrow, some bushings. steering wheel turns a bit when i brake.
Turning while braking is more than likely a brake issue, hoses (either) have cracked internally and are creating a flapper valve, binding caliper, or hardware. Fords are BAD for brake hardware...those guide pins need to be WELL lubed with brake parts lubricant and no rust.
Last week, had the oil changed and all fluids checked.
Noticed red fluid in the driveway after very cold weather. (Tranny fluid)
Specifically asked Jiffy Lube to check the tranny fluid level. They probably didn't so after noticing slipping of gears like action took it back up to have the fluid checked. Sure enough, they had to add quite a bit of fluid. I have a gasket leak at the rear end. Easy fix or very extensive work involved?
Also, for years, my anti - lock brakes actually lock up on me and the car will go skidding many feet depending on the speed of travel. is there a way to disengage the anti-lock system and just have regular old braking ?
Please help. kevinmcgrier@yahoo.com if you have info.
Thanks guys
Had the oil changed today and no i didn't do it myself, i live in an apartment and have no access to a garage with a lift.
Nope not at the moment.
I have both, but still can't, my complex doesn't allow any repairs on cars at all.
That's gotta suck.
 then parked her for a few more months
You gotta be sneaky..Do it on a sunday as most are closed that day. I did my air compressor, wheel repair and other misc things at my old place. Only 1 time during work hours did a maint man tell me to watch for the apt people, and i was only checking the air filter...He didn't care..But i guess it all depends on the apt complex, how the lot is designed ect.
