Lownslowlsc
I used to do this same thing with my cars. I did it a little differently. I used a muti-plug cigarette adapter plug almost like this:
Then I just hardwired it with a long standard 20 amp fused wire from the center console of my car to my amplifier distribution block in my trunk. I then used another short peice of wire to ground the strip under the console. I cut the wire to the cigarette plug on the strip and crimped these two new wires to the wires the power wiring I ran. I ran all the cords from my GPS, Sat Radio, Phone charger, etc to the console and plugged them in to the power strip after tucking the wiring all away. I used two sided tape and velcro to affix the power strip inside the floor of the console, I then hot glued some felt in black to a small peice of balsa wood and made a false floor in the console to cover the strip.
I thought about doing that but didnt want to spend the money..Def alot easier then doing them all seperatly like the way i did it. But mine is still really organized...
Only thing i would change is the location of the strip. i'd prob put it under the dash and run all the wires to the center console.
