I have the same problem with the OD button, no light comes on and it does not drop down a gear when pressed, I'll check my wires too, thanks guys. Not so quick question though, when i bought my 93, the trans. would kick itself out of OD and into neutral while driving, so i let off gas until it would catch a gear, changed fluid and filter and so on, i drove it like that for 2 years until it finally gave out, i got another transmission from everdive three weeks ago, installed it and it does the same d*@n thing, i changed the trans. speed sensor, intake air temperature sensor, PCM, still no luck you drive along at 50 or 60 then kicks out of 4th into a neutral state, rpm's jump from 1700 or so to 3500.... any ideas?
