Blower Motor Dead?
GMAN
Spring, Texas, United States
I guess my blower motor is dead now. I noticed today no air blew out the vents. The compressor cycled on and off and the lines were ice cold. I check the lines underneath to see if the connections were loose, they seemed nice and tight. How hard is it to replace the blower motor? Does the dash have to be removed? Or can the job be done through the glove box?
Mine stopped working one time today too. I just thumped it and worked fine the rest of the day.
Guess I need a new one though. :(
OK, I will try this fix tomorrow. Keep in mind, I noticed that my motor was not blowing very hard. Although I did notice periodic cut outs from time to time before it just stopped all together.
check my response laser...
I checked them when it seemed like it wasnt blowing fast enough when I bought it. They were fine and just figured the blower was dying. After it runs for over 30 minutes it looses speed too even in manual mode.
I found that this wire was burned on one end. Would this cause the blower not to blow?
