NoLimit95
you should clear it first about 2-4 layers then wet sand
Agreed. I never wet sanded the paint when I done it. I cleared it first and then let it cure out for a good 5 days.
When you spray the clear, you might see some foggy white spots, don't worry, it will dry clear. If you see an orange peel look, it will come out when you wet sand.
When you wet sand, it's going to look foggy. If you use the medium cut stuff that I showed you or something of the like, the foggy look is going to start shining.
Use a scratch and swirl remover next and then you'll really see the shine coming through and finally when it's all slick, use your favorite wax to finish it off.
