thaywood
All I can say is
holy crap!
No.
That would be kinda stupid. And quite dangerous. Even a "shadetree" mechanic like myself wouldn't try that one!:lol:
That is what I think about your airbag fix.
Stupid and dangerous.
YouTube- Road Runner & Wile E. Coyote - refrigerator
Maybe we should start a thaywood thread.
Incredible fixes on a shoe string budget.
With photos.
Like here
LOL here is your door handle
Lmfao. This thread is hella funny. Dude, how old r u? Lmao
i am currently 17 years old! no shock there eh? haha its k on that same corolla we used gorilla glue to fill a hole in his tire from a nail, lasted about... i dont even think it was a day.
This has become redonkulous, discombobulated and down right re-re. Google those words. They don't exist like this thread shouldn't. This is stupid and I can't understand why this has gone on this far. Many people have directly said to you 2 guys this is a bad idea. Why am I the only one pushing the fact. When someone searches our forum now this will come up for all kinds of suspension words. And could one day cause damage to a car that didn't want to be damaged.
You mean words like air springs, upper and lower control arms, ball joints, sway bar links, wheel bearings, inner and outer tie rod ends, strut rod bushings, shock absorbers, coil springs, shock mounts, oh I could go on and on.![]()
Other than the hole that houses the solenoid, is there a bigger hole I could put the sealant in? At the top of the strut, there is a big bolt. Does removing that bolt give access to filling the strut?
I should also mention that I am aware of all the consequences of this procedure. Also, this is actually a test experiment to test how this product works with this application. And no, it is not Slime.
if you want to ruin ALL of your suspension components, instead of just having one bad one, by all means do it.
Well if you truly don't care about the damage you are going to do to the bags I would recommend you just drill yourself a hole in the bag whatever size you want to easily fill it. Then you can really test the sealant to see if it fills that hole too!![]()
DO NOT TAKE THE NUT OFF THE TOP!!! As for the sealant, I've got green slime in the front air springs on both of my Marks. I've got a '96 with Arnott front air spring/shocks that are over a year old. No problems yet...knock on wood. I've also got a 1997 LSC with some slight dryrot on the front springs. They were leaking down overnight when I got the car. I took them off and put some green slime in the springs and they don't leak down anymore. That's been over two months ago. I'm not saying it's a good idea, but since I could not afford new air spring/shock units for the '97, I had no choice. I put the slime in the new springs on the '96 as a precaution against dryrot. So far it has worked. I've heard about the crystalization of green slime and how it can damage the air spring. So far, I've had no problems. Also, I've got half a bottle of green slime that's been sitting on a shelf in my utility room for about 3 years and it is just as fluid now as it was when I first bought it.
I added the following to my signature and as of today, the contaminated air suspension system still has not failed. What an excellent car!!
Air suspension bags treated with tire sealant on 4/26/2010
You do realize "idiocricy" is not a real word, right?:lol:
Edit: Oops. It is a real word. Just spelled wrong. It should be "idiocracy". It means a government that is based upon abstract theory. Interesting use of that particular word.
Fortunately, money is not tight for me despite the terrible economy however; my philosophy has always been to not put much money into vehicles and to drive them until they drop. The car is here to serve me and when it no longer does that, it goes to the crushers.
My plan is to buy a used pair of front air struts for cheap. I’ll keep one strut in the trunk with the tools to change it out in case I’m on the road. I’ll also bring some tire sealant along to treat the used air bladders and/or tires.
And most of all, thanks for the tips. I have already saved nearly $400 had I bought new air struts.
And this will be my last post in both of these M.R. [mentally retarded] threads.
This was the first post that started it all
Then it was responded to in this manner
Then this was also said in the same manner
But unfortunately the 3rd reply was from this guy:slam
Now that all the Bs has been said, and the shat was talked. We find out this.
And then more shat was talked for a little.
Then we discovered this,,, that the op is a cheapass who is just going to fix this car cheap and run it into the ground. I personally would rather see one tore apart for parts then drove like an old Omni [not the shelby of course]. We will all have the oppurtinity to see this car jerry-rigged and fall apart.
I guess my point in all this was had Thaywood not given this option this would have never been thought possible by the OP. And that has been my point from the start. GOOD DAY!![]()
while i do not recommend this method of air bag fix, i heard of this being done sometime around 1990-ish, i knew of people who fixed mark 7 and cadillac air bags from cars of the 80's
i bet more than a hundred times,if not more,this has been done.
i would not do it,but i am not shocked one bit that others may try it when they need a cheap repair.
my bigger issue is comparing a jerry rigger mechanic to a shadetree mechanic,they are not one in the same even if a shadetree mechanic may perform jerry riggin repairs ,it is not what determines a shadetree mechanic.
happy sliming!!
This has become redonkulous, discombobulated and down right re-re. Google those words. They don't exist like this thread shouldn't..
I had a 96 Chrysler Concorde with a 3.3 V6 in 2002-03, it was clean and basically boring, barely able to get out of it's own way, and had many issues with rack bushings...it developed a dead miss, and after determing that is was in cylinder #1 I did a compression test, got a high reading, it had spark and the injector was clicking-took off the valve cover, the PEDESTAL for the rocker had broken off, actually a known problem with these engines. Instead of removing and replacing the head, I JB WELDED the pedestal back on, let it sit for 2 days, and drove it for the next 2 years, that fixed it and it ran smoothly. It was a beater, but it ran great and I did disclose this to the buyer when I sold it a couple of years later. He said didn't care and wanted it for his high school daughter's first car-she is still driving it, I see it a couple of times a week, her Dad told me he has never done anything to it other than oil changes, brakes, and rack bushings. It had about 45,000 on the clock when this happened and now has over 150,000.
I have, in the past, done things to vehicles to 'make do', as long as it is not a major safety issue. Now that I have numerous cars, I can park one if it needs repair, but back in the day I did whatever it took.
And, to this day, I still think of what a little McGyverism and JB weld can do.
thaywood
There is a right way to fix problems, and there is a wrong way.
Being cheap or being broke are two different things.
If your broke, I don't think a Mark is a wise choice to buy for transportation.
They are expensive to fix.
If you can't do your own work they become a burden.
I think that has been proven on LVC lately.
If you can do your own work then you should fix the car the right way.
Jerry rigging crap to get buy is not the way to do things, most of the time is going to cost you more in the long run.
Sure you managed to do something most people would not, and you got it to work, by no means does that make it a smart thing to do.
The next guy might get the green crap were it will do more damage and cost more to fix then new bags or a coil conversion.
If you broke OK......good luck doing this.
If you a cheap bastard, and you go this route to pinch your penny's.
YOU HAVE BEEN WARNED NOT TO TRY THIS.
Fix you car the right way.
