Trans Fluid
1994MarkVIII
Central NJ
What type of trans fluid do you guys use and how many quarts? i want to go with a simple fluid. nothing high performance.
Any quality MERCON V
For a filter change I think it's close to 4 quarts, but check it as you fill it so you won't overfill it. For a complete change including draining the torque converter IIRC it's closer to 12-14 quarts, depending on what kind of cooler you have and other factors.
ok sounds good. im replacing 1-2 accumulator springs and pistons, 2-3 accumulator piston, im j-moding the valve body and putting in new gaskets, replacing the trans filter and trans pan gasket, and putting in a new sensor and mlps. for some odd reason my trans is slipping into third and i dont think its the trans itself that needs to be replaced so im starting off with these. hopefully it works!
2-3 accumulator piston was also updated, so he might as well do it while he's in there.
