CrackerJack
Anybody really look into these kits? I watched a video on Streetfire and saw a guy install one of these kits for a friends truck. I read the whole webpage and looked into the technical specs and it all comes out fine!
The only engines that do not work with this system are Ford Powerstrokes. They use a pre-ignition chamber to start igniting the gas before its compressed by the piston for easy ignitions.
As far as how its set up, basically you run electricity through some water, it creates a Hydrogen/Oxygen gas called HHO. This is then run to the intake as a GAS before the MAF. This gas burns 10x faster than gas, fully igniting the gas in the cylinder, also reducing the amount of gasoline needed to run. There really is no performance increase because of this, its mainly used as a gas "replacement" if you will. The only thing I can really think of thats like wtf is when the HHO gas is burned it turns back into water "cleaning the gunk and sludge from your engine" Wouldnt it also screw with the cats? There are a few questions pertaining to the complexity that is the Lincoln LS. Im sure this would greatly help highway mileage! We have plenty of power running highway, if we cut out about 50% of the gas and replace it with a cleaner burning substance we could see 30, 35 maybe 40 MPG Highway.
Most of the systems I saw were for more "basic" vehicles, work vans (E350, Chevy Express 2500) trucks (F150, etc) and even on a prius. Im going to talk to my parents about this, its a fairly simple system that I could install myself rather quickly, (usually about an hour or 2) and I may get a system for my Ranger. Since all its computer knows is "Suck in gas, burn it, suck in more" it should help out.
What do you guys think of this? I dont know if I really want to try this with the LS, but if it DID work, the LS's computer is very smart, and would probably adapt very well, or just complete ignore the gas and pump regular amounts of fuel and f*ck it all up. A ranger though? Hell yeah.
SOURCE
http://www.hybridwaterpower.com/
SOURCE
