Icarus
I know, read the VHT can, I used the same stuff
I know two things.
Make sure the boltcircle is correct.
Make sure the BACKSIDE is beveled.
I know two things.
Why? Cause they are not. Its the front side only.
LOL WUT?
Did you already do this to one of your Marks?
De-burring and beveling enough to call it a bevel at all are two seperate things unless you're larry the cable guy.
Usually lug bolts have a shoulder where the knurl ends and the threads begin. The shoulder in most cases, extends past the face of the hub. If the holes are drilled to match the thread diameter of the lug, the rotor may seat against the shoulders of the lugs before seating against the hub face. Chamfering the backside provides clearance for the shoulders.
Were the original holes chamfered on the backside?
