The reason why I ask is when I had my Sniper I set it to my new tire size which was 25.6" tall. I was told that it does not matter since it wont change anything but with the 245/50/16 tires the speedo was dead nuts correct when it should have been reading 3-4 MPH too fast. Now my 275/40/18s are the same size as the stock tires so the speedo should read correct but since my tune is set for the shorter tires my speedo reads slow. When it says 60 I am doing close to 64. I have confirmed this over the last 400 miles and know its correct.
So my question is do you guys know for sure the tuners cant adjust it or just assume it couldnt since the Mark reads the wheel speed sensors?
I have this nice new fancy SCT tuner now that I need to have coded for my mark and I really want to use it. Would be nice if it would make the speedo read correctly again.
