danny_holtermann
no, i have a storage unit, its a bitch with no electricity
Maaannn... those look killer.. I wonder if those would tuck under my car with the ray switch????
Better than nothing... I've worked in much much worse conditions...
DFL... I am very interested in the Delrin stuff... but damn that is a huge pricetage... and yes I do know how much the raw materials cost... Maybe this summer.
No sh*t, ive got a gravel spot in a storage yard that i work on my 68 Mustang at.
killing looks jp. happy holidays and a better new year to the family from mike's dad and Mike jd
DLF makes some amazing things eh?!
DLF... I am very interested in the Delrin stuff... but damn that is a huge pricetage... and yes I do know how much the raw materials cost... Maybe this summer.
can you get a motor out from the bottom with your 4 post driller? If you can get the a motor and trans out from the bottom with that setup I may have to look into it for myself.
Did you have any clearance problems with this setup? Also can you tell me where you obtained the center caps? Thanks Larry
We had a bag leak and the car would sit down on the fenders atop the tires.
Did you change the upper suspension arm to sub frame bushings? If so what did you use?
Can you give me the Koni Model number, and were they a direct fit?
The same for the brake lines.
Did you use Ed's rear caliper brackets.
