ripped camel
Three runs my best pull was 237rwtq & 225rwhp. Mods are in my sig.
The a/f ratio was hanging in the mid 13 range the whole way through the run. The dyno guy told me I could bump my numbers up a bit more if I add more fuel and get the a/f into the mid 12.5-12.7 range. Thoughts on that?
oil pan gasket leaks, as does the ds valve cover gasket. Would those cause a loss in compression resulting in a loss in power?
All in all I'm pretty happy. I hope bumping up the fuel will put my torque closer to the 250 range and hp closer to 240.
How comparable is my numbers to anyone elses with na bolt ons?
YouTube - 1997 Lincoln Mark VIII Dyno run
