Fortunatly it stayed around 99* out so it wasnt too bad but the 80+% humidity was a killer! I did my strut rod bushings and new struts today and what a MAJOR PITA!!
After I saw the metal sleeve inside the bushings were shot and that the new bushings I got from Maxx didnt come with new ones I had to go hunt. Nobody had them so I figured screw it and bought a bushing set from Autozone so I could use the sleeves..... except they are the wrong size.
So I was forced to use the Autozone bushings which will fail in a year. No biggie, I will order the sleeves from Max and when they go out again I will put OEM ones back in.
Now on to the fun!
First off these cars have a way more rigid chasis then a Stang. My Stang could only do this after FLSFCs (lift the whole side from just the front.
And I couldnt believe how bad the bushings and sleeves were!
Just pulled right off by hand!
And here it is next to a new one.
Drivers side followed by passenger side.
Then getting the strut rod off and the strut off on the drivers side was a big PITA cause nothing would let loose. The ball joints were stuck (I had the tool but was not wide enough) and the camber bolt was in backwards so I couldnt back it out to drop the lower controll arm. Just had to use old fashioned muscle. You can see here I had every nut off but it would not budge.
Passenger side was much easier as the bolt was in the right way.
And finnaly the finnished product.
Now on to the fun!
