doesn't add horsepower you nincumpoop...you should REALLY use the search tool. The SCT fixes the eletronic problems relating to performance of the throttle body..or if I'm not mistaken...the tranny. Each flash will affect it differently letting it get smoother performance...if you have exhaust, CAI and tune you'll be looking at Gen II getting 14.2 average on the 1/4 mile and Gen I getting 14.3 on the 1/4 mile
A very fun device that I hope to have.....try getting the codes from some of the top 2 choices we have here on LVC
aannnnd this is all for v8s![]()
Pete is incorrect.
The SCT devices reflash your PCM programming to:
- give more power and torque
- remove the rev limiter in P/N (limited at 3000rpm)
- remove the speed limiter (non-sport Gen1, all Gen2 limited at 133mph)
- correct the speedo for different size wheels
- firm shifts
- change shift points
- improve throttle response in the throttle-by-wire Gen2
- ....etc, etc, etc
Livewire adds a realtime display, 0-60, hp/torque estimates, ....
I have issues uploading tunes form the Livewire into my Gen1
Here's is my Livewire -> http://www.lincolnvscadillac.com/showthread.php?t=13357&page=23
Here's the thread where we got the SCT devices working on the LS -> http://www.lincolnvscadillac.com/showpost.php?p=27874&postcount=8
Pete is always incorrect...
How much editability is capable with these tuners? Can you completely replace timing and fueling tables? Change injector values? Calibrate for larger MAF sensors?
I believe - it's only limited by the PCM strategy codes (not engine type) that SCT have reversed engineered and have in their database.
so does this mean i can purchase one of these for my 01 v6 sport?![]()
+87
I believe ILLS was playing with some V6 tunes. Try PMing him.
