And... buttons are switched. Going to need another light bulb to get the - button to illuminate better, but that's easy.
Anyways, the pictures:
After tearing out the console and shifter base:
You have to dremel out the plastic rivets, as pointed out here:
Then you are able to separate the black piece from the white base. The buttons are held underneath the black base by double sided tape along one side, and noted here:
Next, is cutting the buttons with a cutting wheel on the dremel. I took a good 5 minutes deciding how to do this. The goal is to make sure that the plastic touches, so the light can still shine through. If not, no big deal. Lights are easy to add
Use a couple spots of epoxy to hold the buttons in place.
Next reassemble everything. Use epoxy in the old rivet locations. Let dry, and reinstall in car. Done
Before:
After:
Before:
After:
