My mark VIII was stolen in front of my college
so that got me thinking how hard is it to steal a Mark VIII? can people just pull those wires they do in movies an start them up? That would be the worest day if my car got stolen.
Mine was stolen in April.
yea.. the alarm..doesnt make much noise when they reach under the bumper cover and yank the horn wires out.
They broke the column and drove the car away...
They tried to steal my girlfriends 94 mark 8 three weeks prior, but the broke the column up so bad the car wouldn't start.
MINE.. GONE... NP..
So.. "I" would worry about it.
IF a crackhead from La Marque Texas can steal one, it cant be that hard.
"Google La Marque Texas", you'll get my drift.
They found the car at a crackhouse in La Marque pretty much destroyed.
All of these newer vehicles have some sort of special key or something to start them, right? Then how in the world do the thiefs steal them without the key? How do they bypass the starter kill? I know they easily do it but how? You would think it would be harder to do.
QUOTE]
IDK if its real but have you seen the movie gone in 60 seconds? when they are stealing the jag, they put in a special digital key which is reading the codes till it finds the correct one and then they start it and drive off. I am pretty sure that jag uses the same technology as lincoln, since they were owned by ford.
I would hook up a simple kill switch to the ignition or to one of the relays needed to provide power to the engine, fuel, etc. QUOTE]
97-98's use the PATS key system
but my 95 that they stole is one of the "smash and grab" cars.
We used a couple of techniques to secure tiffs 94 after the fact, the easiest is to unplug the EDIS module and the car wont start.
Also you can take either the PCM or the Fuel Pump replay in the house with you.
ANYTHING you can do to make the car "not start" will give you a much better chance of having your car "not stolen"...BUT.. REST ASSURED they are gonna destroy the steering column before they "give up".
You can also open your door, then open the fuse panel in the door jamb, and find a fuse that will disable the car.
THEN it'd be easy to wire in a switch to turn the power on or off to that particular fuse.
For instance.. I "think" the starter soleniod fuse is in there.
