AbrahamLincoln
ok, these things are deep inside, i broke it loose but how do i get it to come out? do i need a magnet for this? i try to angle it with my plug sucket but it hopelessly drops out once i start trying to get it out.
yea it worked! any hints on getting at the passenger side plugs? how do i remove the intake tube?
i never take plugs out with a spark plug socket, because if you use it to put them back in the socket pulls off the ratchet and gets stuck on the hole. i use a regular socket and then once the plug is loose, i use a telescopic magnet to get the plugs out, takes about 10 minutes to change all the plugs, easy easy job!!
I just did my plugs tonight as well too
I bought a 6" spark plug socket and put an extension on that and it worked perfect. I wiped down the socket every other plug with silicone lube and it slid in and out easy. Once I got everything out and realized I didn't have a plug gapper anymore, and it was 10 minutes before the stores closed! I drove very dang quick to get one, lol...
The only tough part I ran into in my case was routing the new 10.4mm Taylor Thunderbolt 50 wires. That was a chore!
It definately looks like spring is here with everyone doing their tune-ups and stuff![]()
I'm not sure, I haven't fired up the car yet.howd those wires work out for you?
those are popular wires with the cobra guys
Put the wrenches down and step away from the car!!! Slowly!![]()
everyone loves pictures!![]()
look a bit lean - timings a bit retarded...
anyone wanna chime in on these plugs?
