joegr
Hey, Joe...... Does the AdvanceTrac and PB interface at all? ...
Not that I know of. I do know that the PB and the PCM talk to each other.
Electronic module in the trunk.
http://deneau.info/ls/s6x~us~en~file=s6x65007.htm~gen~ref.htm
Electro-mechanical (actuator) module under the car.
http://deneau.info/ls/s6x~us~en~file=s6x65008.htm~gen~ref.htm
2: Position the notch in the caliper piston up and down to align with the alignment pin on the brake pad.
Going off memory here, when I reset my computer by disconnecting the battery the parking brake light came on, and the message center requested that I apply the parking brake, and release it. Have you tried just applying the brake?
Hey, Joe...... Does the AdvanceTrac and PB interface at all? I wonder if the real problem causing the tone is the proximity of the PB module to the amp...... Just grasping here......
Hey guys so ive been having this problem for a couple months now at first it would pop up every now and again no problem whatever parking engages and disengages fine not bothering me yet plus i had just moved cross country (literally started like the day i was gonna leave) so now its been getting worse im not driving the car all the time now but when i do it seems to be on almost all the time now and beeping a nd just says service parking break or something like that but engages and disengages fine ....what do you think it is ...module in the trunk needs to be swapped out ? i recently just had to change my heater control switch on the dash cause that was wigging out flashign all types of numbers now its working fine again ..but yeah that parking break though...any help is greatly appreciated guys!!
FWIW Forscan App is free on Windows computer...the adapter is cheapThanks for the info im gonna go grab my obd scanner and see what it has i doubt it will be able to hook up to usb its pretty basic but alright if i dont have the proper scan tools i guess it looks like im back to the mechanic from the way its been i dont think its mechanical but i will take a peak at breaks and under the car
If you truly want to flush the system really good yourself I suggest using Distilled water and filling up the system a couple times and opening the pet cock and letting it drain ...otherwise they're is flushing machines at shops that will flush it professionally as you prolly know ...the Forscan app can recalibrate your ABS system which basically marries the ABS system with the PCM also the Lateral steering/Yaw rate sensor can be recalibrated ...as far as the Parking Brake goes it will let you know what the problem is...whether you have a shorted wire or something more serious...you can press the brake in and turn the EPB on and as you let go of brake you can turn it off in order to reset it...you must do this everytime the battery is disconnectedThanks man I didn't know if that's what it was i was looking for i did see that..and that will basically work with any obd2? ..also are there any other steps or advice you can recommend doing? im currently gonna be flushing out heater core and coolant system my DCCV was so shot and so clogged(heater never worked when i bought the car never bothered me til i moved out of cali to freezing ass MI!) lol..thanks man all the help is so greatly appreciated! love this site!
.. maybe thats whats wrong right now cause its been beeping extra obnoxiously since i replaced the battery last week ..will disconnect the battery again and connect then i will try and "reset" the EPB thanks for the great advice.you can press the brake in and turn the EPB on and as you let go of brake you can turn it off in order to reset it...you must do this everytime the battery is disconnected
