Kid_Lyrics
Hey there LVC!!!!
I'm posting my continuation from my "Welcome Wagon" thread.
http://www.lincolnvscadillac.com/fo...-(757)&p=2037396619&highlight=#post2037396619
The reason being: I need some help with my current car. Also, I plan to use this as my build platform as long as I have the car in my possession!
I search back on Craigslist trying to find an affordable car once again...
I come across every single car you can think of.
From the oldes 82 Mercedes to the newest 2004 Camry.
None of which worked out. Too pricy or had too many high value issues
But I searched back for an LS again. I found many 500 and above... the locals all wanted $1,000 or more.... but there was one that didnt show up on CG.
I drove around the corner from my house one day and there were two sitting on two sep streets.
Both between 00-02.
One Silver with more chrome
One Black with less chrome.
Two weeks later, Silver was gone.
Two weeks later, Black wasn't.
Talked to the Black. They initially wanted 1500. I talked them down since I saw they had about 4 other cars... Brought it down to 700.. two weeks later 600....3 days later it was mine. At 140k, All black, Chrome wheels, near perfect condition leather, etc etc. Whew, I had to.
However, it did come with a few kinks.
- Battery had a dead cell. Confirmed by Advanced Auto Parts...
- Front was just flat from sitting. (probably a hole in it) It's bad. The rear is bald.
-I was told from the owners it just needed a coil pack.
- The door handle on the drivers side is broken, needs replacing.. Reaching out the window to get out
- The speakers are shot
- The radio knob is shot
- The trunk says that it is open even when closed
- The tires 2 tires need replacing
- The AC Vent is half broken
Given all of these things I can live with them minus the tires and it not starting. If anyone has any advice. Please give it. I've read on the forums and internet about the fuel pump, relays, PATS, fuel pressure,and fuses.
Would a bad coil pack cause it not to start at all? If that is even the issue?
All in all..... The reviews, the warnings, the cries, whines, gripes, and moans didn't keep me from buying this beauty.
I never knew it existed until now. I'm glad I found it. I just have to get it started....
2 days later...
Alright.... I'm back
I finally got it started. However, It dies as soon as it starts.
The engine will crank, turn over, and then run. Once it runs for a few seconds, it dies. I suspect a weak battery because it's not being charged by the Alternator just yet.
So I'm charging it as I write this. Hopefully that is the culprit so I can at least drive it to the gas station.
Here are some pictures. I'll see if this video uploads as well.
The car has been started and ran a few times, however will not continue to run.
--------THE CAR HAS NOT BEEN TOUCHED IN TWO YEARS
Both between 00-02.
2 days later...
