D
Deleted member 20330
Guest
A 1997 Lincoln Mark VIII base model will not crank after battery was removed for 8 months.
A new Remy starter was installed and the solenoid wire was replaced.
Jumping starter with a screwdriver will cause engine to crank and start.
Solenoid wire is not getting power with ignition in crank position.
With the key in ignition in On position, the fuel pump hums, but the engine does not crank.
The anti-theft light goes out when ignition is in crank / on position.
Solenoid wire from fuse box is not getting power.
Any ideas ?
Any ideas ?
