FDR
thanks i was just about to post here and ask that. I've seen some people here from the past say that their sway bar bushings is what is bad ..
so the sounds that i hear may be just the sway bar bushing? i am going to look under it and see what i can see but as for now where can i get a oem set of all ball joints what not is it something like this for the ball joints?
http://www.ebay.com/itm/LINCOLN-LS-...-SET-/170816164709?fits=Make:Lincoln|Model:LS
and like this for the sway bar bushings?
http://www.ebay.com/itm/Moog-K80246...:Lincoln|Model:LS&hash=item27ecb8d3bd&vxp=mtr
so what can that sound be every time i hit a small bump its a bit hallow like
I have never heard of anything positive about those Deutsche[bag] parts. If you do need control arms, go Motorcraft or Lemforder. My MC arm did not have a new ball joint nut, but my Lemforder did.
Those are sway bar end links, not the bushings you may need. Those are also for the rear. Bushings look like this
http://www.fcpeuro.com/products/jaguar-suspension-stabilizer-bar-mount-xr819697
You can get those for a direct Gen 1 V8 Sport fit. I don't remember what you have, but if you have a Gen 2 or nonsport, you can look around here
After I replaced my bushings, I still had noise. I don't remember if it got any better, but it didn't hurt (the car) to replace the bushings. I later found a loose piece of insulation/sound deadening in the passenger front fender between the wheel and door. It looked like a plastic/foam sole from a size 35 quadruple-narrow shoe. I could knock it around by banging my fist against the fender. The last piece of the puzzle was my front right upper ball joint could audibly rock around. After all 3 pieces were replaced/removed, the car stopped banging around on bumps. Now I primarily hear whatever tools I put in the trunk.
