Markviiiedrea
Speed Bump
Drove my Tuxedo Black Mettalic Kenne Bell supercharged Mark VIII around Sapulpa, OK.
Why is there only one picture? More please!
C head or B head?
HOLY CRAP!!!!!
I's $3.49 for regular here![]()
Got the new speed sensor installed on my '97 'Bird Saturday...didn't fix the problem. CEL still on and O/D Off light still flashing. Still hanging in 1st and banging hard into 2nd![]()
And it's throwing the same code for the speed sensor. I wonder if it's the speedometer sensor? Maybe I'll change it next. Also the A/C quit working. I think it may be the VRCM. It was blowing cold as ice when I got the car. But now when I turn on the A/C, the radiator fan comes on and I can hear a "click" that sounds like the clutch magnet trying to engage, but it also may be the relay clicking also. Can't tell. But I'm going to replace the VRCM before I replace the clutch or compressor. It's just one thing after another...
Just wondering, did you change the fuel filter? A couple of shots of wd on that elbow and shoulder, and they'll be good to go.I have spent off and on for about the last ten days trying to figure out what is wrong with my fuel system. New fuel pump is installed and works but cannot maintain fuel at the rails. Maybe the Crank Position sensor, Ground wires, VCRM a possibility. At any rate, I am going to get the beast running again myself. I am determined not to admit defeat and have it towed to my local indy to be fixed...I do need a "new" ignition switch because after 21 yrs of use it is beat up! My right elbow and shoulder also need to be replaced...after 56 yrs of use they don't like trying to break bolts under neath a car!
Today, is a wash and a wax. I was going to do the claybar treatment, but I'm a dingus and don't have the $19 for the kit until near the very end of my vacation. Sounds lame, but true facts. She cleans up well with a wax alone, but I'd love to be able to finally get all those molehills and little dirt pieces out of the clear.
Jbelcourt - that is extremely sharp. Those clouds in the hood are a direct mirror image. That's what I aim for truly, sans the gorgeousness of new paint, anyway. Beautiful car though, anyway.
I may have a VRCM problem that is preventing my fuel pump from running...I read it is NLA new. Would appreciate any info you have on the VRCM. I have a first gen (93) and wondering wheter there is any crossover to other Ford/Linc models of the same era (e.g., Continental, Marquis). Thanks!
It's possible. The VRCM (or VLCM) contains relays for the PCM, fuel pump, radiator cooling fan, and A/C clutch. And if one relay goes bad, you have to replace the whole module. As far as I know, '93-'95 will interchange, '96 is a one year only part, and '97-'98 will interchange.
On another note, I got my drilled/slotted rotors installed on the 'Bird yesterday.
Now she stops on a dime with no "shaky-shaky".![]()
Rushsampson sir,
I commend you on your choice of car as a DD! Sweet! If you want to be committed, just speaking for myself of course, I believe you have com to the right place! Just ask Thaywood about air struts or is that shocks...lol
Well I wound up replacing the second LCA ball that popped out on Friday drive home from work. Just picked it up from Pep Boys where I had the new 245/45/R17's mounted and an alignment done.
Seems to drive much nicer and averaged better MPG on the short trip home. Now tomorrow I need to do a Trans fluid drain and new filter to finish it all off for the time being. Then search for a new front fender cause the tire made contact when the last joint popped out. :Bang
and I may be alone here, the factory JBL sounds phenomenal.
