96_Lincoln_LSC
I have done my best to correct this issue.
here is what happened and what was done.
1. driving home from work 42 mile, hot day, turned on AC. got onto a main highway, heard a noise, looked at guages, seen the temp was lets say boiling over. Car got so hot the car turned it self off. just tapped the key to make sure it didnt seize. it cranked.
2. Dropped 3 gallons of coolant somewhere. no leak visible no steam on motor
3. inspected the overflow bottle cap, seen the rubber gasket has bad seal.
4. Buddy brings me 3 gal of water, let the car cool off 1.5 hours. add water fill through filler cap not res bottle.
5. drive car home and it boiled over in the driveway.
6. let car cool off another hour or so.
7. fill system from fill tube (cross over - from now on i will say fill and its always from fill tube plug not res bottle.)
let it idle, so much pressure it blew a hose
8. replace blown hose and the rest just for peice of mind.
8.1 do a block test (hydrocarbon in coolant test (Negative Result)
8.2 do a pressure test on coolant system 15 PSI held no issues for 30 min even started car and no change
9. removed thermostat
10. fill the system (see line 7)
11. car runs hot and fan does come on about the R-O range in gauge. take for test drive and when i get home the saftey cap on res bottle is seeping some water.
12. fill the system again. run it let it sit and then fill again.
(I have repeated this process for over 1 and half week not getting better, Still seems to be a ton of air in the system but its not leaking anywhere )
13. emptied system replaced t-stat(yes t-stat is correctly inserted i checked and doublechecked before re-connecting any and all hoses.. filled with antifreeze run the car, runs hot, let cool and then re-fill again
13.1 Pulled all 8 plugs to verify that 1 wasnt cleaner then the rest. they are all evenly wearing. does not seem to be coolant in cylinder.
14. today 6-5 replaced water pump. sparkplug wires and flushed entire system for 60 min. system was ice cold, drained system and then refiled with 2.5 gallons of new antifreeze. also did oil change as its been a while.
took for a spin, car got hot again. im now allowing the system to cool down at this time of this post. will check fluid level and top off with fresh antifreeze.
MY issue is this just how much F'n air is trapped in this system and is there any other test im missing, is there any other way for air to get into the system, could i still have a bad cap or could the pressure be so great its forcing the cap to allow a little coolant to escape.
Where do i go from here. i know swapping the water pump means i have allowed all of that dead space again into the coolant system but is there a fast way to get this resolved or even a slow way but a sure way to get it to settle down... i use this as a DD and have to work on it after i get home from work every day.
PLEASE PLEASE HELP ME.....
anyone local to Bristol PA (Philadelphia Area) that can offer up some help psychically ?
