Ready4Wings
Hi everyone, this is my first post outside of the Welcome Wagon forum.  I used the search feature and didn't quite find what I needed.
I have a '98 Mark VIII LSC. My husband recently had a devil of a time replacing the passenger side lower ball joint, and the car was on a jack stand for one week (we did shut off the air ride switch in the trunk first).
When he flipped the switch back on and started the car, the compressor kicked on, the front end rose, and he drove it around the block. However, the "CHECK AIR RIDE" message appeared. He brought it back, let it sit for a while, and tried it again. The compressor came on, but the front end stays low.
While he was working on the ball joint, he noticed that the air bag looked "deformed" (his words). He sprayed some WD-40 around the clamp.
He's thinking there could be a short in the sensor. Any ideas? Some background: even before he started work on the ball joint, the front of the car would drop if it sat for any length of time (say, more than 4 days). However, the air ride would kick in just fine until then.
Thank you! :steering
