I found an air ride toy, Maybe!
NoLimit95
Huntsville, Alabama, United States
$125 for everything. Does it look like it will work?
You would likely also need a tank.
On top of that, you would also need lots of hoses/tubing, fittings, and more than likely, some different solenoids.
You definitely wouldn't want to use those air cylinders, and you'd have to come up with a different way to get air into the air bags that you have. I'm not sure how well the plastic assemblies hold up to drilling/tapping for the necessary larger hoses. I know I've seen it with the metal ones, but can't recall if I've seen it done to the plastic ones...
IDK, just some things to think about.
Could make for a "fun" toy, but they'd more then likely turn into paper weights imho.
they look like SARC struts off of a Taurus.
97 Conti and he has the 260HP engine too for $350
Another one of Thaywoods favorites lol
The ad: THE ENGINE IS A 4.6 32 VALVE INTECH MOTOR OUT OF A 1997 FRONT WHEEL DRIVE LINCOLN CONTINENTAL, THIS MOTOR HAS 260 HORSE POWER FROM THE FACTORY.Solid motor.No smoke.Starter comes with it. Motor is complete except for alternator.
Wiring harness included.
Tail lights too for $100.00 I wonder if the neon from those would work in a Mark? Or did they have neons...
oh ok. then yeah, essentially the same set up as the taurus.
front wheel drive with struts. thaywood is gonna have a heart attack.
He'll love it. :lol:
I don't think they had a neon. They had the same set up as a gen1.
Rich, I have no clue. Just figured since it was a 97 that it might have a neon in there. Seems like I recall seeing one lit up all the way across like a neon would light up but idk for sure.
