Stopsign002
So, heres my issue. My battery seems to drain in about 12-15 hours to the point where it cant start the car. This started happening maybe 2 weeks ago. The battery can be charged just fine, there just seems to be some sort of drain. Now I installed LEDs in the interior and the license plate a few months ago. I've noticed they dont completely turn off as you can see in this picture:
Now this didnt cause any issues initially which makes me believe it is something else, but I figured it was worth mentioning. My father and I plan on going through and trying to pull fuses to see what is causing all this drain. Do you all have any suggestions for things I should try and look for? The only thing that changed in the last two weeks is freezing temperatures. Anything pop into your mind about that causing some trouble? Like I said, the battery seems fine. I just jumped it a few hours ago, drove for 20 minutes to my gym, worked out for 2 hours and the car started up with no hesitation. It almost seems like the car isnt putting the electronics to sleep or something
