Trying to buy a tune but it says EEC code
Trippen Out
Pinellas Park, Florida
So im trying to purchase a tune from blue oval chips and while filling out the spec sheet. it tells me to enter a valid EEC. I was pretty sure this was the strategy code you get when you check your car with the sct xcal. however it isnt taking and it tells me " Please enter a valid EEC code"
so whats a valid EEC code where do i get it?
EBP2
FRS2
PAA0
SQF0
TYT0
WWX2
something like that.
Is there a way to pull that info with out actually pulling the part its self ?
the computer is actually very easy to get to.
up above the gas and brake pedal, you pull off the plastic clip and then you can swing the computer down.
read the code, and swing it back up. easy.
Ok cool. so is there anyway to find out what it is with out actually pulling the computer ?
My google search skills are sucking at the moment and what is the point of the "strategy" code then ? i thought that was the "catch" code required to upload a tune
There can be alot of different #'s in the same year. That's why you have to actually read the code off your computer.
Maybe my google fu is better then i thought
PAA0 1996 CDBA4KC.HEX
this is a post from another forum that list a lot of codes and what not
5521, RE: Need Help Compiling EEC Catchcode List
Posted by Dennis, Thu Apr-19-01 05:11 PM
CODE YEAR TEMPLATE
A4X2 1993 CCAQAE4.HEX
A4X3 1994 CCAQEE8.HEX
A5W0 1994 CCAQEAA.HEX
AAB2 1995 AKAM6AZ.HEX
AAB3 1995 AKAM7A2.HEX
AAB4 1995 AKAM9A5.HEX
AAB5 1996 AKAM9A7.HEX
AAB6 1996 AKAM9A9.HEX
AAF0 1998 ALAPLK6.HEX
AAM0 1994 CGAK2S6.HEX
AAM1 1994 CGAK6S6.HEX
NSI2 1999 RHAG7B3.HEX
NSL1 1999 RBAECGZ.HEX
NSL2 1998 RBAEDG2.HEX
NSU0 1998 VJAE0H5.HEX
NSU1 1998 VJAE1H2.HEX
NSU2 1998 VJAE3H2.HEX
NTD0 1996 AGANFKZ.HEX
NTT2 1998 PDAE3BB.HEX
NTT3 1998 PDAE3BI.HEX
NTT4 1998 PDAE3BG.HEX
NTT5 1998 PDAE3BK.HEX
NTT6 1999 PDAE3BR.HEX
NUX1 2000 RVAF1T4.HEX
NUY1 1997 MAAG4J9.HEX
NUY2 1997 MAAG4JB.HEX
NUY3 1998 MAAG4J3.HEX
NVK0 1998 VJAE0U4.HEX
NVK1 1998 VJAE1U4.HEX
NVK2 1998 VJAE3U3.HEX
NVK3 1999 VJAE3U5.HEX
NVK4 1999 VNAA8U5.HEX
NVK5 2000 VNAA9S4.HEX
NWL0 1998 KNAG5RY.HEX
NWL1 1999 KNAG5RZ.HEX
NXU0 1999 BUAE0BX.HEX
NXV0 1999 PAAD8AC.HEX
NXZ1 1996 BLAE1B4.HEX
NXZ2 1996 BLAE5BZ.HEX
NXZ3 1996 BLAE6B2.HEX
NXZ4 1997 BLAE6B3.HEX
NXZ5 1998 BLAE7BY.HEX
NXZ6 1998 BLAE8B2.HEX
NXZ7 1998 BLAE8B4.HEX
NXZ8 1999 BLAE8BX.HEX
NYC0 1996 CDAN4PD.HEX
NYM0 1998 GRAK8EC.HEX
NYM1 1999 GRAK8EG.HEX
NYY1 1998 RDABBL3.HEX
NYY2 1998 RDABCL2.HEX
NYY3 1999 RDABCL4.HEX
NZA0 1996 AJAP4T7.HEX
NZA1 1996 AJAP5TZ.HEX
NZA2 1997 AJAP5T4.HEX
NZB1 1996 APAD1J4.HEX
NZB2 1996 APAD2J8.HEX
NZB3 1997 APAD2J7.HEX
NZQ0 1999 ANAJ8B4.HEX
OAT4 1995 CTAA6S9.HEX
OAT5 1996 CTAA6SC.HEX
OER0 2000 PDAE6HX.HEX
OIV0 2000 PDAE6J7.HEX
OPT0 1995 AJAQ3SZ.HEX
OPT1 1995 AJAQ4S2.HEX
OPT2 1996 AJAQ4SZ.HEX
OVD2 1999 MPAM0N2.HEX
OVD3 1999 MPAM1N6.HEX
OVD4 2000 MPAM1NW.HEX
OWN3 1995 CTAA6S8.HEX
OWN4 1996 CTAA7S4.HEX
OWN5 1996 CTAA7SZ.HEX
PAG1 2000 JAAT2SX.HEX
PAM0 1995 AJAQ3F3.HEX
PAM1 1995 AJAQ4F3.HEX
PAM2 1996 AJAQ4FA.HEX
PBL0 1995 AJAP4A5.HEX
PBL1 1996 AJAP5AZ.HEX
PCC1 1997 RAAD3U3.HEX
PCL2 1995 CDAN3TD.HEX
PCL3 1995 CDAN4T4.HEX
PCL4 1996 CDAN4T7.HEX
PCM2 1999 RHAG7H3.HEX
PDC1 1997 MAAF2R5.HEX
PDC2 1998 MAAF3R3.HEX
PDE3 1999 RHAG8C2.HEX
PDE4 1999 RHAGBC5.HEX
PDE5 2000 RHAGBCC.HEX
PDL2 1998 PDAE3B6.HEX
PDL3 1998 PDAE3BC.HEX
PDL4 1998 PDAE3BZ.HEX
PDL5 1998 PDAE3BE.HEX
PDL6 1999 PDAE3BL.HEX
PDR1 1998 PAAD8B4.HEX
http://www.markviii.org/htdocs/dc/dcboard.php?az=printer_friendly&forum=21&topic_id=5515
edit:
Edited the list to save space :)
not really.
it has to do with how the computers were written and what files were put on them for a particular car.
if you're running a tweecer or similar, you need to know the strategy code, but for a chip, most tuners only need to know the catch code.
its really not that hard to pull the 'puter.. like chris said just pull the clip and jiggle it till it swings down. then just put er back :)
yea im gonna do that in the morning. i want to be 100 percent with the proper info when it comes to a mail order tune.
Thanks you all for the info.
I had to do the same thing a while back; no need to pull it out
...remove the LH door bottom plastic and rubber weather stripping then the plastic trim panel to the left of where your left leg is when you're driving, u also have to pull the plastic cover that sits above your knees; light up the area and stretch your face up there; i couldn't clearly see the code, so I snapped a photo with my phone-camera....my tune rocks, 3rd gear goes FOR-EVAH!
After it changes into 3rd, how long until the TC locks? I hate how early mine locks. And before i even know it, I'm in 4th at 40 mph.
I'll double check later, but (w/ OD OFF) it seems to pick up 3rd around 35-40 mph; and then can stay until about 65-70 mph with modest to accel.....my custom tune is the best $$ (260) I've spent on this ride so far...that mushy spot around 40 mph and 2400 rpm's is gone daddy gone!...shifts stiffer as well, feels almost like a manual
So i just ordered my tune. Anyone know what the turn around time is for an email tune from xlr. should i not expect anything for a week or so. or should i start getting all pedal happy soon.
I I have better driveability when I leave od off until I am over 40mph. The reason it is like that is for best fuel economy. A tuner can change things to make the car a bit smoother under lighter throttle conditions, but sometimes you have to request those changes. From what I recall, I think my tuner said he could diminish the effect some by delaying lock-up under lighter throttle conditions until a higher mph. I decided against it because once that parameter is changed, you cannot force earlier lockup under light throttle conditions where you may want it to happen for better economy. My od button gives me that flexibility. Try turning your od off at lower cruising speeds. It does make a big difference in the way the car acts. I use my od button probably more frequently than the brake pedal. Lol. I think my high stall and deep gears exacerbates this effect.
Man this waiting stuff sucks. its almost been 10 days since i ordered the tune. i wonder if ill get it before the 1st
holidays, alot of those performance shop guys are covered up
i i have better driveability when i leave od off until i am over 40mph. T. Try turning your od off at lower cruising speeds. It does make a big difference in the way the car acts. I use my od button probably more frequently than the brake pedal.
+1
right. im still waiting on my speed-o gear too. was hoping that would of come in today. curse the blasted holidays. probably wont see it till wednesday. I know i can't wait until i dont have to worry about how fast im going and doing math :)
I know i wont install the tune till i get the speed o fixed. but im still excited like a little kid waiting for it
