chris2523
93 Mark VIII
Nice indeed!
Sooo about those brakes...
fronts fit. he started another thread, might have missed it..
here:
http://www.lincolnvscadillac.com/showthread.php?t=83858
Nice indeed!
Sweet! So is that the Advantage one that lets you do full programming? If so I'm looking forward to hearing how you like it. My ordering one has been delayed a bit due to stuff at home. My wife and I have some surgery coming up in the next month so I'm trying to finish up existing projects. No new ones until after we both recover.
Its been a while since I've been on here, sold my ls due to needing a suv for the wife(ls was hers). I was considering keeping the ls and doing a engine swap to a 302 or 351 but couldn't find the info on the wiring. Your build gives me new hope about this swap and I might try picking up another ls with a blown engine and trying it.
Approximately how much did the engine and trans swap wind up costing? I have a lot of experience with the 302 and 351 engines from various mustang builds and would love to build another stroked 351 (last mustang was 351 based 393 tuned on e85) for a ls. 470rwhp in a ls would be a lot of fun.
You could pay 2200 (that was the quote I received) and have someone make a Jag flywheel to mate with the manual trans and then spend another 3k to throw some turbos on the factory engine -- at least things would fit better.
Those are two mods I would Fin' kill for lol. If I could get my LS Turbo'd and manual I would be in heaven.
Hows the car doing anyway dwiggy?
I just bought a Honda S2000 EPS rack and controller. I'm going to swap that in after the tuning is straight to get rid of all the front end hydraulics.
I am VERY interested in this. How do you plan to make this work? I've been trying to come up with a reliable way to get the power steering pump off my truck's engine. I don't mind the hydraulics and was looking at doing something like a Toyota MR2 pump, but those are getting to be rare as hen's teeth. I've also been trying to find something along the lines of a standalone CAN controller that would allow me to use a newer CAN controlled steering pump. No luck so far.
This would be worth a new thread and a separate project. When you take those pics, some measurements would be great too, like mount to mount, end to end, ect. Also, don't know how much you know on suspensions, but if you aren't already aware look up bump steer as switching to this rack can cause bump steer if it's not set up right.
Cool, looks like you've done a lot of research on this. I'm in no hurry. I'll have to see if I can even use a rack in my 4x4 truck, which is what I'm working on. If it'll work I'd prefer to use a lightweight rack over the heavy steel components my truck currently uses. The 4x4 is only used in the winter, I'm not an offroader.
Incidentally, the 2001-2005 Toyota MR2 electrohydraulic pump has its own built-in controller. All it requires is power, ground and a VSS signal so there's no problem with using one or having it be speed sensitive, the only problem is findind one in good shape. I can get one from Toyota for 550 bucks, which is a bit steep for me at the moment. A lot of other people have made this conversion (part of why they are so hard to find) and report that this conversion works really well at all speeds.
Mike at More Power Tuning.Who is doing your tuning?
If this is what you want to do, plan, save, purchase the right parts, and do it right.
You'll make more money but you'll never make more time.
No worries there. Been modding vehicles to suit my own needs for over 20 years now.
