rear glass
Sapperfire
Waco
Just loading some pics for someone that asked, my email doesn't want to work today
To remove the glass start in the top center from the outside and work your way to the corners, then the center of the sides, I used a long serrated blade to saw thru the corners, then sawed the bottom loose. I would suggest removing the inner 1/4 panels, rear dash mat, and headliner before you begin. Some guys use a battery pack sawsall once they can get the blade in there
Used a da sander to remove the old glue from the car, and a long box cutter blade to clean the glass
How is this done without scratching the sh*t out of the paint near the window seal?
Elfin magic
Or put painters green tape around the edge, the trim lifts up
The man from the glass shop that came out and removed the back glass from the 93 I had here and removed the glass from the black 94 so that he could install the 93 glass in the 94, used a sawsall with a semi sharp putty knife on the end and he got inside and went to town and had both removed within 20 min or less and then installed the ripple free 93 glass into the 94, all for $119 total. Seemed fair to me but anyway, that was his removal method. I had pics of him doing it on another picture host but they apparently shut down and now I can't find the picture card that has all of those pics.
Doing it by hand Sapper, I commend you for that. Doing it like the glass man done it looked to be a job itself. I couldn't imagine going about it all by hand. I remember him getting to the upper corners and he had fun on those two spots. :D No interior was removed from either car.
Removing the interior is only suggested in case you're a clumsy sort, it didn't take me all that long, maybe 15-20 minutes - having a SHARP knife makes all the difference
I've always worked with my hands, I wasn't permitted to be a lazy kid when I was little. I can still do pushups on a single finger each hand
Pinkies only?? :D
Lol, I can't do my pinkies, but I can every other finger
No, I figured I'd just leave it out, makes vacuuming the back deck so easy
