SleeperMark
So I need to find a 93 ds now.. How hard is that to replace
Holy SMOKES! Pinion does NOT move in and out at all when crush is set. It sounds like you never crushed the collar at all. I don't know how you would get any setup #'s with crush not set. You might have already killed them. Oh also an impact gun does NOT crush the collar or any impact I own. You should have just asked for help.
250 ish. But problem is you might have done damage already. Also It would have to be a complete tear down because I would not trust anything in there. You where also "pounding" the pinion bearings by not setting preload.
hindsight is always 20/20 should have taken it to a shop especially having never even looked inside a rear.
i ordered my trac loc and gears from
http://www.svtperformance.com/forums...play.php?f=320
3.73 or 4.10 ford racing gears 125.00 new in box if yours are shredded (sorry but probably are) and i cant find a place anywhere in south fla less than 325, for a rear swap on a IRS and you'll have to make sure all those metal shavings didn't screw up your diff.
driveshaft is easy, found a couple for 80-120 on carpart.com they are gonna have to take it out anyways when you redo rear but if there is anything salvageable do not move the car, please.
Whoa whoa whoa. Please tell me i'm seeing gr81 seperating his thoughts. I think I need to be pinched.
