poniesviii
I haven't taken the glass out yet, but it turns out you can cut the visible section of the seal off and urethane around it and it doesn't look bad. Stays in all the way to 130mph so far. The seal is urethaned in, and the seal is absolutely stuck to the glass, it holds. The glass sits flush with the body and doesn't look bad. Just have to be careful not to gouge your body, cause that blade will slip with no warning. I used a carpet knife. I'll see about getting a picture up sometime soon.
