will this shifter work?
wish i could change the shif nob on my 95 continetal but for starters i cant even get the dam thing off :q:q:q:q iv tried everything
I have the billet one instead of the black anodized one. So, yes they will work. The only thing is I am not sure what the interior looks like in the gen 2 as far as the T/C switch. If you have a T/C switch you can simply rewire the O/D button to the T/C switch as I did....instead of using the O/D button from UPR, but that switch will work as well.
Here is a pic of the shifter in my car:
think the button may work with the stock shifter handle
i need a nitrous button but haven't been able to come up with anything that looks halfway descent
Do as Ray did with his OD & T/C switches and put the OD switch along with the T/C switch. This frees up the stock OD switch to use as a nitrous trigger thru a latching relay with a WOT switch for a safety along with an rpm window switch for launch delay. :nos:
i was going to use the od switch befor but i want a switch that is off when i let off
the od switch needs to be depressed again to release it
i had a window switch on it but found no need for it on this car so i took it off and sold it
When are you gonna put a boot or something over the rest of that stick?
Just wondering...
