ripped camel
I'm interested in having a posi rear end put in my car with gears. Will this setup be a direct plug and play with the Mark VIII? Will I need to change axles or anything else with this specific differential?
"2006 Ford Mustang posi differential. 8.8 ring gear and 3.31 ratio, 28 spline side gears. 35k miles
Also have the same but from a manual transmission model (07) with the 3.55 ratio with 20k miles. Differential and gear packs only, no axles or housing
Should also fit late model Explorer, E150, F150 and Crown Vics but check with the dealer to be sure"
Thanks...
Thanks...
