A Aviation Well-Known LVC Member Joined Apr 12, 2006 Messages 206 Reaction score 0 Location Maryland May 18, 2014 #1 Can you get to it after taking the wheel off without taking anything else off?
A Aviation Well-Known LVC Member Joined Apr 12, 2006 Messages 206 Reaction score 0 Location Maryland May 18, 2014 #2 This is on the drivers side btw... Probably gonna need to do the passenger before too long as well but the driver side i can yank on without jacking it and its loose and clunks cant do that with the passenger side but still looks old but not as bad
joegr Dedicated LVC Member Joined Dec 10, 2005 Messages 21,572 Reaction score 2,364 Location Gulfport May 18, 2014 #3 Aviation said: Can you get to it after taking the wheel off without taking anything else off? Click to expand... There's a bit more to it than that. http://deneau.info/ls/s6x~us~en~file=s6x41008.htm~gen~ref.htm
A Aviation Well-Known LVC Member Joined Apr 12, 2006 Messages 206 Reaction score 0 Location Maryland May 19, 2014 #4 joegr said: There's a bit more to it than that. http://deneau.info/ls/s6x~us~en~file=s6x41008.htm~gen~ref.htm Click to expand... ahhh okay so u do have to remove the reservoir tank
A Aviation Well-Known LVC Member Joined Apr 12, 2006 Messages 206 Reaction score 0 Location Maryland May 23, 2014 #5 Got the part from rock auto and a tie rod end. Might tackle it this weekend. Is there a link Joegr to the index of the workshop manual you linked for the upper control arm? I want to see if there is one for the tie rod end and use it for future reference if I need to change something else Thanks
A Aviation Well-Known LVC Member Joined Apr 12, 2006 Messages 206 Reaction score 0 Location Maryland May 23, 2014 #6 Nevermind I got it
