dertyclown
wow 13.935@109.04 Are you having some problems hooking up? @109 you should be mid or low 13'sQuik LS said:well - my best time slip is -
- 13.9350 @ 109.04mph.... so bring what evar your 5000 lbs wants....
dertyclown said:wow 13.935@109.04 Are you having some problems hooking up? @109 you should be mid or low 13's
How hard is it to set the speed tracker up and how accurate is it?LBK_LS said:Ahhhhh... Forgot about the traction control. Ok, no D5... Thanks! Gonna use my AutoEnginuity sorta-speed tracker and find out my sorta-times![]()
whatsupadrian said:lucky the car won't let you shift late. Any idea why the has has such an early red line?
MikeB said:How hard is it to set the speed tracker up and how accurate is it?
Mine gets here tomorrow. :wrench
LBK_LS said:You'll have to ask someone w/ another type of device.. Quik LS has one...
Lucas05 3 said:If I ever want to quickly accelorate I put into 1st then 2nd and then 3rd. I don't have SST so I to was wondering about it. I hit 4th at about 90 right before the redline. The problem I have now is that I don't really have a D4. If I put it into D4 it shows up D5 on the message board but during last winter after shifting it manually a lot, it finally recongized it when I was toping out. It actually reconized 4th and put me in it becuause I could feel it stay in. Now it is back to the point where it is always D5. Anyone have any ideas about this. When I shifted manually my 0-60 was .2 better, and I upshifted right before hitting the redline because of the long delay.
whatsupadrian said:Ok took my car to this industrial area last night and did a few launches, Its a long strait stretch nicely paved in walnut its about 2 miles long. I would hit about 120 and i wouldn't climb further but i didn't feel my engine dieing off to limit my speed. Is this supposed to happen? Am i at the "tire" limit that the PCM has? Also before a race should you reset the car by disconnecting the battery for 10 mins so that the adaptive learning lears that you like to drive really fast? Also, my 0-60 is not fast at all, its like nearly 10 seconds. Anyways i am going to take out my 200lbs of stereo crap and take it for some more runs some time soon to see if that makes a difference at all.
Quik LS said:I believe the non-sport pre-03 and all 03+ were limited to 133mph by the PCM.
The adaptive learning is more for shifting firmness than anything else.
should be in mid-6 for 0-60.....
fuel filter? plugs? ...
brentalan said:Quik LS wants to know if you have changed the plugs or fuel filter at all, 10 seconds is way off....
I had that same problem about my message center not recognizing the switch from D5 to D4 and vice versa.. The center stayed at D5 all the time.. but every other position (P,R,N,3,2,1) were noticed.. I took it into the dealer and it was the shifter itself.. they replaced the entire shifter and it works great.Lucas05 3 said:If I ever want to quickly accelorate I put into 1st then 2nd and then 3rd. I don't have SST so I to was wondering about it. I hit 4th at about 90 right before the redline. The problem I have now is that I don't really have a D4. If I put it into D4 it shows up D5 on the message board but during last winter after shifting it manually a lot, it finally recongized it when I was toping out. It actually reconized 4th and put me in it becuause I could feel it stay in. Now it is back to the point where it is always D5. Anyone have any ideas about this. When I shifted manually my 0-60 was .2 better, and I upshifted right before hitting the redline because of the long delay.
:FERIC1 said:the best way to drag? hmm dress like tim curry in the rocky horror picture show. now thats drag baby.
