vikingdiesel
Turns out I dont have a HYPERTECH chip, instead it says MAX RPM "BTLO". This could by my hesitation issue
whats what I thought, i was looking for you on my other post. The car just bogs, should I remove the 80mm MASS AIR FLOW and just put everything back to stock?
YES.. ditch the big meter that you dont need.
pull the chip.. and see if the issues subside.
MAXRPM sounds like a LMS chip from Geno... if I'm not mistaken.
BTLO doesnt sound right either.
Are you sure it isn't BTC0?
it might... lol.... it was written with a permanent marker, it might say BTCO, but kinda looks more like BTLO
n00bs...
WTF did I tell you? This may come as a shock to you, but I read a pamphlet on Mark VIII's once.
Catch code is on the PCM. PRINTED, not written in Magic Marker.
its a 98, I should be looking on the chip itself or go back to the car?
Also, on the bottom of it, a small chip says "HYUNDAI KOREA"
so its not from GENO? Also, back to that MASS AIR, the MASS AIR sensor is the same, its just the tube (pipe) is larger in diameter. Would that still cause my bog? Also, after how long will it take for the car to remap itself? Maybe I just have to keep driving?
