Turn Signals in Mirrors (M3 style)
Quik LS
Austin, TX
M3 Mirrors
I've wanted to update my mirrors to M3 looking mirrors for a while.
Here's what I did:
- purchased the el'cheapo mirros from e-bay
- then I cut out the clear signal window lens
- I then 'trimmed' the lens with a dremel tool
- I took my LS mirrors off my car
- I then cut a hole in my LS mirror housing
- I then epoxy’ed the clear lens in the hole
Here's the result:
I then:
- wired in two amber bulbs into the mirror interior housing
- one pointed to the outside (toward the clear lens)
- one pointed inside
I also drilled in 3 puddle lights:
- one toward the clear lens
- two in the bottom of the mirror housing
I then wired the lights up:
Here's the diagram for the turn signals:
Hooking up the signal wires were tricky - as the LS uses a multiplex wiring system - there is a Front Electronics Module:
HOLY Toledo again what a job, want to fly to Ohio and install a set in mine!?
Nice work great discreption and detail!
-Scott-
to Add LED V-Signals in your mirrors:
while you are at it:
LED V Turn Signal Mirrors
I followed the instructions posted a while ago from the Taurus Club:
http://www.taurusclub.com/modules.php?name=News&file=article&sid=106
I purchased :
- 12,000mcd RED LEDs off e-bay (100 LEDs for $18)
- 560ohm resisters from Radioshack
I then
- soldered 9 LEDs in parallel into a V and attached a resistor to one leg
- covered them in glue to keep it water tight
- pulled the mirror out of the housing
- pulled the mirror out of the plastic holder
- peeled the heater pad off the corner of the mirror (and cleaned the glue goop off the mirror)
- cut enough of the plastic housing away to mount the LEDs
- filled the cavity with black silicon sealant (to keep it water tight)
- attached the LEDs to the turn signal wires (already in my mirror from my earlier project)
took a couple of hours - but pretty easy.
Oh yeah! I remember this project. Very nice and detailed instructions. Looks good!
I think we all need to find a cool custim project to try to one up Quik.
Quik do you still have this on your car? I was thinking of doing it myself and it looks kind of hard.
Has anyone else done this?
sure - those are the stock mirrors so they are on the car.
I think itsnotmydaddys did the LED Vs.
I don't think anyone else tried the M3s....
I might give this a try. I guess now I have to find the cheap ones on ebay so I can take them apart.
