Mechanicboy
Are you sure that the play is in the differential and not in the CV joints at the back wheels?
I was installing the magnaflow cat-back yesterday and while under there I decided to try and find where my drive line play is. It's coming from the CVs closet to the differential equally on both sides. It's not much play but enough to be felt/heard. I'm learning to shift different mainly by taking all aggressiveness out of the shift seems to result in a nice, clean, bump free shift.
Thanks mikey, You've been right on all this.
Now the only thing left is my high idle issue. It's not the PCV valve or elbo and it's not the IAC. Several people have told me to use starting fluid but I don't like using it near electrical wiring or rubber hoses. I really would rather use propane which I don't have access to at the moment.
