Mechanicboy
Ok, I've searched, and I've read the manual but I just want to ask a few questions and clearify a few things about maintenance on my LS I just bought with 125k miles on it. I'm assuming that the 100k maintenance was not done.
1. Engine: 5w-20 Probably going to use Mobile 1, Really almost 7qts? Any filter to avoid or is great?
2. Manual Trans: Mercon ATF, what's a good synthetic?
3. Differential: 75w-140 synthetic, does it really have to be that thick what about 75w-90? I do live where it gets above 100 degress F
4. Coolant: Green all metal with water wetter
5. Power steering and Fan: just plain ATF.
6. PCV valve: whatever Napa has?
7. Sparkplugs: NKG G-Power Platinum
8. Brake/clutch fluid: DOT 3 good?
9. Fuel filter: Motorcraft good?
10. Hinges and latches: White lithium grease good?
11. KKM intake: Can I clean this with K&N recharge kit?
Let me know if I'm missing anything or if you have a suggestion.
Thanks in advance!
Thanks in advance!
